Brief Description: Empennage Attachment Section 11-6 Vertical Stab to
9/10/2008 … Add the Vertical Stab to the vertical stab Front Spar Attachment bracket VS-1016. And then added both Horizontal Elevators (L/R) to the Horizontal Stabilizer insuring that they still swing freely with no resistance. Created the push rod assembly from the 1 -12;” OD aluminum pipe F-1091. Riveted with MSP-42 and added the Rod End Bearings and adjusted as described in Figure 2. Time about 1 hour.
