Brief Description: ROD END BEARING AND JAM NUT INSTALLATION, and AIL
6/01/2009 … Section 23-3 Steps 4 and 5…. ROD END BEARING AND JAM NUT INSTALLATION, I installed the Jam Nut AN316-4 onto the F3414M Rod End Bearing and then screwed the assembly on to the Threaded Rod Bearing AN490-HT8P for both W-1018A rod assemblies. Step 5, AILERON BELL CRANK SPACER FABRICATION, I created two SPACERS by cutting a stock piece of aluminum AT6-058 X 5/16 inch to the exact length of 1 and 1/16 inch. Time about 1 hour for both Flaps.
