Conrads X-10 Build Log
Date: 9-22-2009
Number of Hours: 1.00
Manual Reference: 29-10 Steps 1 & 2
Brief Description: Section 29, FUSELAGE SIDE SKINS …. Pages 29-10, St
Section 29, FUSELAGE SIDE SKINS …. Pages 29-10, Steps 1 and 2 Step 1, First I created two wooden blocks about 1 inch in lengthen and diameter to fit into the inside channel of the F-1041-L Lwr (lower) Fuselage Channel and then twisted the channel after placing in a secured vice, see figure 1 with a vice grip pliers. The amount of twist was 20 degrees as specified in figure 2. Then I created the same amount of twist in the F-1041-R (right) Lwr Fuselage Channel. Step 2, Using the same method as Step1, I created the F-1040-L Upper Fuselage Channel to the 8 degree twist explained in figure 3.
Also, I finally got the cheap shitty Sears Bandsaw fixed, (NEVER BUY ANYTHING AT SEARS) the service charge was $150 dollars but because it was under warentee for 1 year the price was waived. Anyway its fixed and I cut both the created F-1033-R/L Control Column Mount out perfectly because I did not want to remove the hatched area with a hack saw.
Time about 1 hours for both because I was working slow after work.
