Section 29, FUSELAGE SIDE SKINS …. Pages 29-8, Steps 1 to 4 Step 1, Located the small F-10100 Baggage Door Shim and cut into two parts; F10100A and B Baggage Door Shims Step 2, Final drilled #30 all the holes in the upper flange of the F-1023-L/R Baggage Floor Angles. The dimpled for the correct sixe rivets. Step 3, Clecoed the F-1023-L Baggage Floor Angle and the Baggage Door Shims to the F-1070-L Mid Side Skin. Then I final drilled #40 all the holes in common. Step 4, I clecoed the F-1023-R Baggage Floor Angle to the F-1070-R Mid Side Skin and final drilled #40 all holes in common. Time about 1 hour.
