Measured the distance from the forward side of the pedal support bulkhead to the aft side of the fuselage firewall flange at 12" each side of the fuselage center line.
Cut the two lengths of 2” wide aluminum channel, 1/8" shorter than these two measurements and fitted brackets made earlier in accordance with the manual.
