Serenity
Date: 9-9-2007
Number of Hours: 3.00
Brief Description: Pitot mast, recheck fuel tank
I had missed some non-critical rivets in left wing under the tank skin overhang (rib to spar) early on, and it was time to fix it. Left tank was removed. While off, I placed 4 gallons of mogas and moved it around, checking for leaks - none. Fuel siphoned off, evaporated out (will have fumes for potentially years, so NO FLAMES will ever be nearby during construction), tank closed up. Re-attached tank, torqued all bolts. The million attach screws were next - I used a torque wrench to adjust the clutch on the cordless screwdriver and then just ran them all in. Lastly, I cut the wing hole for the Gretz pitot mast (have the Dynon pitot tube with AOA port), drilled out, primed, set aside for later install when lower wing skins riveted.
Getting ready to cut mast hole
Gretz mast with Dynon pitot
