Installed pitot and AOA (Angle of Attack) lines (SafeAir kit) through the left wing. I decided to locate the pitot mast inboard of the bellcrank one bay to keep clear of tiedown lines and the ring.
SafeAir kit - well worth it. Has push on fittings.
Drilling pitot tube holes to 3/8" with angle drill and step bit. Snap-in bushings then put in.
Left plenty of line at the wing root for running in the fuselage.
