Brief Description: Mounted taxi light into wing, installed lens
Finished up - installed assembly in wing (recall that the assembly is way forward compared to the DW plans to increase lateral light dispersion). Lens was installed - as mentioned, I could not mount the outboard side reflector I made - too little room. I ran 16g Tefzel wire to the ballast, and fired up the lightwith the power supply. Works well! Later, I will haul the wings outside and test the lights in situ.
Note side reflector to the right of the round lens
