Finished taxi light assembly and made side reflectors to disperse light more laterally (tested this on the bench). I made these from ,016" scrap, mounted them with platenuts and screws. Worked well, but later I found that I just couldn't fit the lens and get the outboard reflector in place, which is OK since I don't want much reflection on the back of the prop. Last pic show the final assembled structure before mounting in the wing. The main bracket is from the Duckworks kit, but the xenon bulb mounting plate, bracket, and ballast shelf were all fabricated from scrap.
