Brief Description: Finished landing light and tested
Finished lens and attached light. Foam weather strip added after lens finished, then light mounting plate put in wing and screwed down, lens final attached. I added enough 16G Tefzel wire to make a run down the wing when the conduit is installed. I took LE out to street, and tested light (pic 3). Bright. Beam a little narrow for my taste, but good for a landing light. I ordered the taxi lens (wider beam via a scattering lens) from Don at DW for the other wing.
All done - front view
From behind inside - ballast on right, bulb and lens on left
