Finished fabricating mounting plate, tested bulb focal length out on street, then made spacers from metal and rubber washers, made a mounting plate, drilled out back of bulb, then JB Welded everything together. Retested light after hooking up to battery.
Spacer made to hold bulb back a bit, and hold down bracket fabricated
Fabricated plate I made and spacers
Bulb with igniter attached, hold down bracket screwed on
