Serenity
Date:  5-23-2007
Number of Hours:  3.00
Brief Description:  Right landing light
Started Duckworks landing light install. Tracing mask applied (modification - 1.5 inches from inboard rib, outer bay. This way, outer plex lens can slide out fo the way, as it won't be easy to remove through the LE hole as I'm moving the whole light assembly forward compared to the instructions). Cut out opening with a new toy - an air saw. Very easy to use, was able to cut almost to the line. Files and sanders to bring cutout to line, then scotchbrite/die grinder. Lens attach holes drilled, and rib attach holes done, nutplates added. Light mounting plate cut and reattached to proper length (note - I cut off the smaller side closest to the lens opening to align with the LE hole).
New toy alert - the pneumatic body saw. Like butter!
Final sanding - clean edge
Cut mounting plate, shortened, riveted. Also fabricated HID ballast attach bracket, installed.
