Serenity
Date: 2-10-2007
Number of Hours: 3.00
Brief Description: Fuel tank leak test
Well, today was the big leak test to check the tank. A small amount of pressure is introduced to see if it leaks out anywhere both by gauging an inflated balloon vs. making a manometer. I chose the latter - some tubing from the local Menard's Aircraft Supply (1/2" ID for the fuel line nipple, and 3/8" ID for the vent line nipple, but I used 1/4" rubber tubing here). In pic 1 is the assembly - the manometer tubing placed in a 'U' shape and taped to the tank support, then I added water with red dye via the green funnel. I attached the tubing to the nipple with a little grease and a small hose clamp. The vent line had the rubber tube connected, and on the other end I clamped on a bicycle innertube valve. I then sealed the fuel cap opening with dict tape, and pumped the tank with a bike pump until the water was pushed up 12 inches (per Dan Checkoway's suggestion at www.rvproject.com). Had a quick leak - culprit was the duct tape not sealing. Fixed that - still a leak! Sprayed soapy water all over - found the leak at the outboard rib end to rear baffle seal - muck of it was bubbling away. I likely forgot to slather it up with sealant before assembly. So, how to fix it?? It is always better to seal from within, but the tank is closed up. After a little mental masturbation, I came up with the rig in pic 3 - a 35cc syringe attached to some brass tubing that I bent so it will slide into the fuel cap opening and I can caulk the seam. It was very difficult to push the thick as tar sealant through, but it worked great. I closed off the cap opening with duct tape, and re-pressurized the tank - NO LEAKS!! Glad to have that over. Now, I have heard you only need 1/2 PSI to test, so how much with pushing a 12 inch column of water in a 1/2"ID tube? Pi R squared X 12 " gives 2.4 cu inches of volume, and .09 lbs weight on a 0.2 sq inch footprint (water weighs 62.4 lbs/cu ft). That works out to 4.5 PSI if my math is correct, so more than enough to check the tank (in fact, one does not want to pressurize it too far).
Manometer set up
bike pump attached to the innertube valve clamped to the 1/4" rubber hose
My homemade sealant caulk "gun". The problem area was the upper horiz edge of the tank in the pic.
