Finished vent line. Fabricated fuel pick-up line - bent 3/8" tubing, cut to length, cut a series of slits with the bandsaw to make a pickup 'screen' (see bottom right corner in pic 3), cut a notch in the tip and squeezed the tube end. It was then installed on the access plate and sealed. These later kits have an anti-rotation bracket that has facets that match the attach nut, so one doesn't need to safety wire these as per Van's safety bulletin.
