Drilled upper wing skins. Cut to fit two J stringers that run along upper skin through rib holes (pic 2). Thought he instructions are confusing, they only come to the inner and outer rib edge. An overlap is near the skin overlap. These were match drilled with skin (pic 1). Next, I attached lower skins, drilled out (pic 3).
Drilling and clecoeing skin to underlying stringer
