Serenity
Date:  11-17-2006
Number of Hours:  3.00
Brief Description:  Put together trim servo, finished right elevator T
Trim servo cover plate and supports clamped, drilled out, deburred. Screwed up platenuts on servo opening earlier (they were flat, whereas the cover plate attach holes are dimpled for #6 screws - I found the proper platenuts in the servo parts bag), so all 7 were drilled out, new platenuts with countersink openings installed. Servo was attached, tested with a 9 volt battery, everything put together, and installed for now. Last, the right elevator TE was riveted as per the left - came out nice. All is done now, except lead counterweights and to install onto the horizontal stabilizer.
Electric trim servo on cover plate
Dead straight, baby!
Just about done!
Just about done!
