Today we began bending and twisting the left rear canopy skirt. We first used the pneumatic cut off wheel to trim it to shape leaving approximately 1 inch of margin around the outline provided. Later we trimmed it down to 1/2 inch. I then started dragging the skirt over the edge of the work bench at a sharp angle. Later we found that we could get the twist and bend better by dragging the skirt over a piece of PVC pipe. Image #1 shows that we almost strike the rear fuse skin. I think that with just a little more tweaking and when we drill it and anchor it with clecoes, it will fit nicely. We now have about 1/8inch of clearance in a short area laterally and are touching everywhere else.
