We had planned to put the panel back in this morning but being Memorial Day we couldn't find anybody to help us lift it into the plane. We tried to plan how it will go in and it may not without removing the roll bar. This would be a mess to do. SO we will try every way we know how to get it sneaked under the bar. We decided to start work on the canopy until we can get help on the panel. We cut the canopy rail into 2 pieces, drilled them according to plans and primed them. They will be clamped to the canopy deck during fitting of the frame. See image #!. We then drilled the 661 plastic clip and then drilled it in assembly to the rear of the canopy frame. and bolted it on. It seems to be able to rotate freely. See Image #2
