Brief Description: Parts for front deck-wiring of tail strobe
I began to wire the strobe and nav light for the rudder. It was quite a learning process! I successfully put pins on both the tail and at the power supply and covered them with shrink-wrap as can be seen in Image #2. I then plugged the pins into the connectors for the rudder as can be seen in Image #3. Then I remembered that the wires should have gone thru the rudder end cap BEFORE putting the connectors on. I got a pin-removing tool but even with this tool I was only able to bet 5 of the 6 pins out. I think that the pin remover is not the correct size. While I was doing this wiring, Claude was fabricating various parts for the front deck structure (see Image #1)
