Brief Description: Fitted the pitch survo plate/Drilled out rivets/Dr
Today was much cooler!!! We primed the strobe power supply plate after shaping it to fit the stringers. We didn't get the plate riveted to the J-stringers because we got started on the pitch servo which also mounted to the elevator bell crank in the same bay. There were no instructions sent and only a sketchy drawing. We went down to the FBO to see if there were more instructions on the TruTrak web site but there weren't. After some deliberation, which both Claude and I do really well, we fitted things in place and drilled out some rivets that were interfering, drilled the mounting plate and primed it. It all seemed to fit well and like we saw in the picture. Tomorrow, I guess we can rivet it in place as well as the power supply plate. We were able to work much better today because of a drop in the temperature.
