Brief Description: Assebled/riveted rt. brake pedal and both rudders
We drilled, coutersunk, riveted and assembled the right pilot's side brake pedal and then assembled both brake pedals and master cylinders and drilled the holes to align the pedals. We then primed the inside of the rudder pedal tubes and the outside of the right brake pedal. Claude drilled the center nylon block and I took it by Mack Dean's place and he cut it in half for us. We will be able to finish the rudders/brake assembly on our next work session. This weekend is Labor Day weekend so it might be Tuesday. I don't know if I can wait that long.
