After getting home from work today Jonathon and I started to unload the crate and sort through everything. In some ways its surprising how little there is, but in others its surprising how much there is. Everything is labeled extremely well and everything (but the hull) was packed very well. My only gripe about the hull is PA could do just a little bit more bubble wrap and maybe cardboard protectors where hull is against crate - both sides and top lip (which is down against bottom of crate). I was very impressed with all the hardware packaging and labeling, should make it very easy to find what you need. A printed manual came with the kit, although I had already downloaded an IPad version a few weeks ago and had been studying it.
Anyway, it is obvious that putting the hull onto a little cradle with some casters would make the workshop flow much better and allow me to push the plane around when I need to, I'll start on that tomorrow - right after Andrew and I fly my Dual Cross Country to Graham, just north of PK, that will be awesome!
Crate Packed Well, hull still had minor scratches
Jon helping unload - Wonder if I could put some forks on the front of his wheelchair... Hmmmm...
Everything is out of the crate, Definitely will need cradle!
