Chris's RV-14A Site
Date:  9-24-2018
Number of Hours:  5.00
Brief Description:  Engine prep
Getting the engine ready to run. Removed the bottom plugs and opened the oil drain bolt and removed the preservative oil in the cylingers and sump. I added a quick drain valve to the sump to make oil changes easier later on. I added about a 1/2 qt of oil right into the oil cooler to partially pre fill that and then added mineral oil to the sump to bring it up to full for the weight and balance calculations coming up soon.
