Did the fuel flow testing with the electic fuel pump flowing 5 gallons in easch tank back into a can. Right tank took 6min 47 sec or 44.25 gallons fer hour. Left tank took 6 min 45 sec for about 44.44 gallons per hour. In any case, it's plenty to cover the 125% of required for takeoff. Once the tanks were empty I drained the remaining gas to get the unusable fuel readings which were essentially identical at 7oz per tank. Installed floor pans temporarily and installed the seat belts and secured the wiring for the overhead dome light.
