Brief Description: Seal and base coat left wing and aileron
Applied sealer to the left wing and then 2 coats of white base coat. The left aileron had sealer on it from a couple months ago so it got a quick scuff with 400 grit and then base coat applied. I made a couple mistakes on the bottom of the wing that need to be sanded out and resprayed before clear is sprayed but it's just a couple small runs.
