Added the right intersection fairings with the epoxy filler to make a custom fit for each part. Made the "lug" for the upper left fairing which came out nice once I understood what they were trying to have us do. Basically you are making a back stop for the leag fairing so it doesn't move farther aft than the lug. Also, you are capturing a nut in the epoxy mix so you can screw the back of the fairing together. Made up the epoxy mix to seal the left lower fairing around the wheel pant so it sits nice and flush. Lots of sanding and final shaping of this to go.
