Brief Description: Fuel system and starting flap mechanism
Installed the cabin fuel lines from Aircraft Specialty. The pre bent hard lines fit perfectly. The teflon / stainless braid line from the fuel pump through the firewall was installed as well. Began to cut the UHMW material for the flap inboard and outboard bushings. The outboard bushings were installed.
