Brief Description: Finish fuselage mating and starting fuel
Completed the riveting of the rear fuselage mating - just needed to add the seat belt attachments to the top skins and rear bulkheads. Moving now to section 31 fuel which is installation of the fuel and brake routing brackets with pull rivets and then preparing and installing the fuel valve, fuel pump and filter. The pump need to have some connectors crimped on so the electrical supplies are needed before starting this step.
