I needed to install the floor in the cockpit and baggage area so I could work on some wiring behind the baggage area. While I had the floor in I decided to have a little fun and put the seat in and try out the fit some more. With the Almost RV-14 crossmember mod, the cockpit has plenty of room. I might even have to add a little bit of cushion under the seat. I'll decide for sure once the canopy is in place. With the new reclined position my sight line is much lower than before.
