More work on the cooling plenum. Not real exciting stuff this week. I fitted the angle that attaches the plenum to the baffle at the rear, front corner, and front center. This work was time consuming since I have to notch the angle so it could bend and match the contour of the baffle. If I had planned on this plenum from the beginning I would have just made everyhting straight to keep it simple. I have installed all but a few of the nutplates. Once I finish those last few all that is left is to mate the inlet to the cowl air inlet.
