I actually spent quite a bit of time fabbing up this part. I didn't end up using a single piece from the parts Vans supplied in the kit. The fit of the Vans parts was poor so I decided to just make my own. I left the bottom support a little long for now. I will trim it as needed once I fit the gear leg and intersection fairings. I still need to drill the holes in the brace for the hinge pins, but the is easy enough to do.
