Today I fitted and glued the intake air ramps to the top cowl. I used some locktite 3200PSI quick-set epoxy. This product come with a mix-tip, so it went straight from the dispenser onto the cowl. I like the epoxy, it is tough as nails. Not cheap though. One tube was enough for both air ramps. The ramps will get more fiberglass and filler later.
