Today I finished the mounting brackets for the trim indicator junction box and mounted the trim relay deck to the seat rib. I connected the one trim servo I have to the pitch wire and powered the trim system from a battery. The servo and indicator both worked great. This is my first test of the relay deck and indicator system. I probably should have tested them and I fabricated, but it all wored out. I also tested the roll circuit and it worked great also.
