I am adding a test and dim circuit to my annunciator panel above the EFIS. The test button will light up all the indicators to make sure they are working. The dim selector switch will dime the lights for night operations. I need to pick up a push-button switch for the test fuction, but I drilled the holes for the switches now.
I forgot to run the wire for my stall warning back to the right wing terminal block, so I havd to tear back into my (I thought) finished harness. That took some time.
I made a little ramp for some of the wires going down from the forward harness. This way they can't rub on the edge of the metal.
I started reworking my dimmer panel (again). A little while ago I cut a new face plate. Today I cut some metal for the support bracket and started drilling all the holes and mounting the dimmer circuits. I got rid of the RGB LED strips along with the selector switch. I am going with whilte lights and three dimmers. 1) Instruments lights, 2) Glareshield lights, 3) Flood lights.
