More electrical work. I decided that a second crossmember is needed to cross the wiring from one side of the fuselage to the other. I fabricated this part using the 0.032 angle and some brackets that attach to the longerons. The member is supported in the center as well. This piece it intended to only support the wiring so it isn't super rigid, just enough.
I am using this second crossover for signal wires while the forward crossmember is for power. This should help prevent electical noise in the Comms ect.
As soon as the new crossmember was installed I started connecting wires where I could. There are plenty more to add, especially once I throw the comm, xponder, and audio panel in the mix.
