I didn't have much time to work today so I only got a little more done before I had to break everything down again. I pulled the left fuel tank and worked on the connections for the pitot lines. When I biult the wings I followed the plans which called for the aluminum lines run behond the tank. Since then I decided to use the safe-air plastic lines and quick connectors. Because of that, I had to connect and adapter to the aluminum lines and figure out how I wanted to route them into the fuselage. I ended up putting the adapters behind the tank. I still need to add a couple more clamps to support the adapters, but I can do that when I fit the wings again later.
With that done, I put the tank back on and Gina helped me take the wings off and put them on the storeage cart.
