With the fiselage back in the shop I did a little work tonight. I made the doubler for the fuel-tank attach bracket. In the picture, the spacer in the middle is out of alignment, I just need to twist it into position before torquing the bolts.
I also started making the lines that connect the fuel tank to he selector. That routing is all kinds of fun getting around the gear tower and into the selector housing. I might re-make this part to see if I can do it with fewer bends to provide better flow. The first try didn't come out to bad at all.
