I got a lot of work done today. I will have to make two entries for today.
First off I finished riveting the rear spar together and adding the elevator hinge brackets. I set the rear spar aside and assembled the front spar by riveting on the spar bars and the inboard ribs. Per the manual, the center nose rib gets riveted to the skin first (without and of the spars in place 0 for access). The front spars are then installed and riveted to the ribs and skin. One half of the stab is assembled at a time.
Left half of the stab riveted together (less rear spar)
