After the left half of the stab was assembled I started in on the right side. This is where things get a bit more challenging. The spars are once piece at this point so the two halves of the stab are connected, but since the rear spar isn't in place yet, it is very flexable. I had to be careful to keep the assembly from twisting excessively and causing damage. Once the inboard ribs and front spar were riveted in place I installed the rear spar to stiffen up the assembly. I got the vast majority of the riveting done before I shut down for the day. I only have a few areas left to rivet and the horizontal stab will be done.
