Brief Description: Drill Hinges to Left Seat Floor
Did the hole layout for left side hinges and drilled to #40 on the drill press. Learned from right side and moved holes so none interfered with screws or ribs. Match drilled hinges to floor with #40, then went back and drilled up to #30. Dis assembled and deburred all holes.
Did the layour and cut out the F-741 left and right tunnel cover supports.
