Watched Karetaker video on brake/rudder assembly and it really helped to get the picture of how it all went together. Marked the F-6116 side blocks with a silver sharpie to get proper orientation and location for mounting holes. Drilled mounting holes on the drill press to try and be as accurate as possible. Did the same for the F-6115 center block and cut it apart on the band saw.
Did the layout for the F-6118 per the plans. Not sure how to drill the relief hole at the corner since the location is very close to the bend. Set aside to think about it.
Set up the paint table and primed the brake parts with NAPA 7220 self-etching primer.
