Drilled and reamed to #10 the holes for the brake pedal pivot bolt. I will be using one long bolt to mount the pedals instead of the two short ones in the plans.
Countersunk the holes for flush rivets in all the pedals and the master cylinder brackets.
Used scotchbrite and emory cloth to scuff all the parts to prep for primng. Washed all parts in Dawn dish soap and warm water and set out to dry.
