Brief Description: Canopy preparation for the "Big Cut"
I have the canopy positioned where it need to be, I will make the cuts, tape the cut lines and remove the protection film on the cut lines and go to work cutting the canopy next week. I will leave the bottom long until I can clamp the Plexi to the frame with the Sika spacers and determine the finished length. The windscreen will not get done until the very end when the instrument are wired and the top forward skin is riveted in place.
Rear frame slide and adjustment
The canopy is touching the fames all around the top
A very close fit except the bottom which is just pulled out a little from the mould
