Carl Bells RV7A N947CB
Date: 2-7-2009
Number of Hours: 4.00
Manual Reference: GRT Manual
Brief Description: Manifold plumbing and pressure box
OK, so, after talking to Ed Booth, I decided to go first class and use AN fittings and hoses for the manifold pressure in front of the firewall, Ed told me if you get a leak in the manifold hose, it can lead to leaning of the number 3 cylinder and cause critical damage to the engine. Its not the pressure, but just the chance of a leak. It can get pretty hot in front of the firewall, so an AN fitting and hoses are in order. It did cost $49 for the Aeroquip 666 hose made up to 20" from Aircraft Spruce, which is the downside. Oh well, it’s only money and being 62, I’m on the back nine!
Pressure sensor box
AN bulkhead fitting & doubler
AN fitting in engine
