Brief Description: Fuel flow mounting and plumbing
This probably does not look like anything significant, but the time it took time to find a way to get 5" of straight tube into the fuel flow sensor and 3" of straight tubing after the sensor was significant. This is a requirement for accurate reading. I tried at least three different locations to get it right, and I believe this location is the only practical solution, so other builders with I/O 360s, this is the best way, trust me! Wiring and wire routing is next for this very important system, stay tuned.
The perfect spot as if there is any other place to put it.
