OK, this doesn’t look like 4.0 hours, but it was and I have one more to go. I will do the left side next time in the shop and make the small tube to the pump when I get the additional fittings from Aircraft Spruce. Because I am going with a fuel injected engine, I need the high pressure fuel pump which mount right below the fuel shutoff valve. The AN 832-6D fittings will attach to a small 3/8” tubing elbow that in turn attaches do the Andair fuel valve and pump. I’ll take more pictures when its done because there is little room to get this all hooked up and I think I broke the code on how to do it. The best way to get the gas line bent from the tank to the pump is to make a stiff wire template, then slip on the rib support, slide it through the leg mount and then bolt the leg mount in place one you are sure it all fits in place.
3/8"Line to the main wing tank
Aroung the main gear mounts to the pump bulkhead
Thjis will be a AN 832-6D fitting, not the one shown
