Brief Description: Match drilling fuselage to wing skin
I didn’t like the idea of trying to measure the location of the bottom wing to fuselage skin attachments hole locations, so I went with using a strap duplicator. It turned out by using a wood wedge I could easily slip in the strap duplicator a drill the holes. I really believe this is the best way to get this done and recommend it. I will add the nutplates once I pull the wings.
Strap duplicator and a wood wedge to slide it in place
Ready to drill
Completed, all holes Matched drilled for a perfect fit
