Carl Bells RV7A N947CB
Date:  8-13-2009
Number of Hours:  3.00
Manual Reference:  Dwg C2-C3
Brief Description:  Wheel Fairings Part 1
I also started the wheel fairings, first by getting the seam as tight as possible with a sanding block and then marked and drilled #40 holes at the platenut locations. Tomorrow I will get it mounted to the brackets and work on the intersection fairing.
Wheel fairing separtion seam
Clecoed at the screw nutplate points
Left leg fairing is finally straight
