Carl Bells RV7A N947CB
Date:  8-14-2009
Number of Hours:  6.00
Manual Reference:  Dwg C2-C3
Brief Description:  Wheels Fairings Part 2
I continue to work on the fairings and at the rate things are coming together it will take a few more weeks to get all three wheels and gear legs done. This is just very exacting work to keep the leg fairings in perfect flow with the center line of the airplane and also getting the wheel pants in line with the longerons. Then the gusset fairings at the intersections get add and have a tendency to change the alignment of the leg or wheel fairing. The right one is clecoed in place, once I get the other ones build, then the cuffs need to be glassed in place.
1" Spacer block for clearence spacing
Intersection fairing
Wheel fairing mounted to brackets
