Carl Bells RV7A N947CB
Date:  5-29-2009
Number of Hours:  5.00
Manual Reference:  AeroElectric Z11
Brief Description:  Wiring the master switch
No real description is required here, standard Fast-On terminals connect to the switch and the other end goes to power/fuse bus. I tested it briefly and the pump came to life. You can’t do it for long because it will damage the pump when there is no fuel present.
Master switch with fuse link
